Hi Tristan, I've heard similar problems, a lot of the time, when folks upgrade to 1.0.4.17, they don't reset the router to factory default. This firmware upgrade was a major upgrade and seems to have some code overlap to the older firmwares.
If you can take the time to reset that unit and give a manual config, I think it will work ok.
-Tom
Please rate helpful posts
-Tom
Please mark answered for helpful posts
http://blogs.cisco.com/smallbusiness/
