RV260 PPTP NOT EASY?
ezequiel30801
Hi, Im From Argentina,
I buy a new Cisco RV260 to use VPN in my job, but is not easy to begginers.
Actualy i have a RV320 with PPTP configurated whitout any problem.
Anybody have a link or a config to help me?
Sorry if my english is bad!!
Thanks!
ezequiel30801
thanks @Martin Aleksandrov and @marce1000 !!
The pptp vpn was not the problem, the problem came from the windows configuration,
I have observed the following solution and it has worked wonderfully!!
https://community.cisco.com/t5/small-business-support-documents/pptp-vpn-configuration-on-rv340-345-routers/ta-p/3220097
marce1000
  - FYI (e.g.) : https://www.youtube.com/watch?v=NdiLDnIODLU
 M.
Martin Aleksandrov
@ezequiel30801
You may also have a look at the following guides. It is a quite straightforward and similar configuration to RV320 PPTP setup:
This is with the split tunnelling config.:
https://www.youtube.com/watch?v=mC9IlHcph7E
and with the RV320 including the Windows VPN client config.:
https://www.cisco.com/c/en/us/support/docs/smb/routers/cisco-rv-series-small-business-routers/smb4359-configure-point-to-point-tunneling-protocol-pptp-server-on-r.html
Martin
ezequiel30801
