RV320: Advanced Routing Question
thiesy123
we have different local networks (192.168.200.0 and 192.168.203.0) which are connected to the RV320 by using port-based VLAN.
Inter-VLAN-Routing between these networks works perfectly since I added some firewall rules.
Now there is a Gateway2Gateway IPSec-VPN connection to a /32 Network (255.255.255.255), local network is 192.168.203.0 (/24, class c).
How to nat queries from 192.168.200.0 to 192.168.203.0 ?
At the moment RV320 is sending these queries into Internet instead if routing into VPN.
Maybe a static route will help?
thiesy
joedon30412
I would just create a static route to point the packets in the appropriate direction.  Is there a reason you are trying to NAT?  with a Site-to-Site VPN, you only need to route the traffic.
