So I just purchased a RV320 ....
1 - My LAN IP network is 172.18.x.y/16 -- is there any way to set the RV320's IP address as 172.18.100.235 ? I could not find it ....
2 - VPN -- I have IPSEC VPN's working between Cisco 2901, 1841, and 1711. I would like to copy the VPN config section from the "old" routers to the RV320 -- is there a way to get into the RV320's via telnet or ssh ?
3 - When I try to activate an IPSEC VPN the 320 seems to want to make it an SSL VPN. Im getting message regarding some sort of OAKLEY negotiation. The messages go away when https is turned off in the firewall settings at which point administration also reverts to http.
Please help ! Im trying to avoid having to return this router.
Juergen
