10-04-2013 09:56 PM
Good morning,
any ideas ?
I am trying to make a vpn tunnel from one location to another ...
situation a : cisco wrvs4400 router
situation b : rv120w router ...
all is setup but this is my log error
[rv120w][IKE] ERROR: Ignore information because the message has no hash payload.
2013-10-05 05:54:13: [rv120w][IKE] INFO: Using IPsec SA configuration: 10.0.0.0/24<->192.168.0.0/24
2013-10-05 05:54:13: [rv120w][IKE] INFO: Configuration found for ..............
2013-10-05 05:54:13: [rv120w][IKE] INFO: Initiating new phase 1 negotiation: 85.234.195.185[500]<=>81.82.192.144[500]
2013-10-05 05:54:13: [rv120w][IKE] INFO: Beginning Identity Protection mode.
2013-10-05 05:54:13: [rv120w][IKE] INFO: [ident_i1send:180]: XXX: NUMNATTVENDORIDS: 3
2013-10-05 05:54:13: [rv120w][IKE] INFO: [ident_i1send:184]: XXX: setting vendorid: 4
2013-10-05 05:54:13: [rv120w][IKE] INFO: [ident_i1send:184]: XXX: setting vendorid: 8
2013-10-05 05:54:13: [rv120w][IKE] INFO: [ident_i1send:184]: XXX: setting vendorid: 9
2013-10-05 05:54:13: [rv120w][IKE] ERROR: Ignore information because the message has no hash payload.
2013-10-05 05:54:23: [rv120w][IKE] ERROR: Ignore information because the message has no hash payload. 2013-10-05 05:54:13: [rv120w][IKE] INFO: Using IPsec SA configuration: 10.0.0.0/24<->192.168.0.0/24
2013-10-05 05:54:13: [rv120w][IKE] INFO: Configuration found for ....................
2013-10-05 05:54:13: [rv120w][IKE] INFO: Initiating new phase 1 negotiation: .........................[500]<=>......................[500]
any ideas ?
10-06-2013 01:06 AM
After some wigeling and changing all is working
This problem is solved, it was a wrong pasword encryption setting between routers
