RV320 - DDNS - update top domain
andreig1978
Hi all,
Does anybody know how can I update a top domain for the DynDNS service?
I am using my own domain name, which is being handled by DynDNS - btw, it's a little frustrating that I had to transfer it from no-ip because Cisco only supports DynDNS.
So, going to the Dynamic DNS configuration page I select: DynDNS.org and for the host name I have three fields. The documentation sais:
  • Host Name—Hostname that you registered with your DDNS provider. For example, if your hostname is myhouse.dyndns.org, then enter myhouse in the first field, dyndns in the second field, and org in the last field.
The problem is that I don't want to update a hostname but the whole domain (e.g. mydomain.net not gateway.mydomain.net).
I tried:
- leaving the first field empty ->error, cannot save
- using * for the first field - saves but gives the following error: No internet connection or DDNS service is disabled
- using @ for the first field - saves but gives the following error: No internet connection or DDNS service is disabled
Thank you,
Andrei
31 Replies 31
Don't hold your breath :)
No reaction from Cisco about this issue. :-(
The last Firmware 1.1.1.06  is from Dec. 2013.
