em 06-24-2015 02:31 PM
Recently installed an RV320 in our office as we needed something that could handle multiple WAN as we wanted a backup connection for our Exchange server.
The router constantly drops the second connection after a short amount of time (1 day? I don't know I don't check it constantly)
The router sees the second connection as connected, but the IP addresses is 0.0.0.0 -this is a programmed static IP from the ISP. The ISP claims it's not their issue as it works (for a short period of time). We can get an address using DHCP, and it seems to stick for a while, but this does not work to use as a secondary mail connection.
I upgraded to the latest firmware - no luck (although it wiped all my settings and that was fun to restore - exported the settigns, but when I imported ti was blank)
Anyone else having this issue? Anyone help me change this so that it works reliably?
em 06-24-2015 03:07 PM
UPDATE:
I have got the second connection to come back - unknown for how long. Will keep this thread posted.
I let the modem acquire a DHCP address, then reverted to static IP and it seemed to come back ot the correct address. Although I cannot ping the second connections IP, but I can ping the first connections IP - this could be due to our server config though.
The only concernign part at this time is the "Inactive" flag on the connection. Screenshot attached.
em 06-25-2015 02:11 PM
Logged into the router this afternoon and the IP was zero's again. No internet in WAN2. Anyone have a similar issue?
Descubra e salve suas ideias favoritas. Volte para ver respostas de especialistas, passo a passo, tópicos recentes e muito mais.
Novo por aqui? Comece com estas dicas. Como usar a Comunidade Guia do novo membro
