RV320 - EasyVPN Setup and Android 5.1.1
curtisho120
I have been tackling this problem for a month but couldn't figure it out. Hope I can get some help in here.
Running the latest firmware of RV320 (v1.2.1.13) Setup EasyVPN on the router and trying to connect via Android 5.1.1 native. However, I am getting the following error.
[grpips1][4] x.x.x.x/24=== ...x.x.x.x===? #8: [Tunnel Authorize Fail] RC5_R16_B64_CBC is not enabled for this connection. Attribute OAKLEY_HASH_ALGORITHM
Tunnel Type: EasyVPN
Tunnel Name: testVPN
Interface: WAN1
Tunnel Mode: Full
Extended Authentication: Default - Local Database
acidburn1669
Im having the same issue with RV320  , Reboot clears the issue.
Easy VPN , with IPSEC Enabled. After a reboot clients can connect . After some time connections fail  , with only PPTP working .
Error Logs below
2017-07-02, 08:00:13 VPN Log [grpips1][13] 10.0.20.0/24=== ...82.9.102.84===?: [Tunnel Disconnected] grpips1 instance with peer 82.9.102.84 {isakmp=#0/ipsec=#0}
2017-07-02, 07:59:57 VPN Log [grpips1][13] 10.0.20.0/24=== ...82.9.102.84===? #19: [Tunnel Established] sent ModeCfg reply, established
2017-07-02, 07:59:57 VPN Log [grpips1][13] 10.0.20.0/24=== ...82.9.102.84===? #19: [Tunnel Established] received XAUTH ack, established
2017-07-02, 07:59:53 VPN Log [grpips1][13] 10.0.20.0/24=== ...82.9.102.84===? #19: [Tunnel Established] ISAKMP SA established
2017-07-02, 07:59:53 VPN Log [grpips1][13] 10.0.20.0/24=== ...82.9.102.84===? #19: [Tunnel Authorize Fail] received Hash Payload does not match computed value
2017-07-02, 07:59:53 VPN Log [grpips1][12] 10.0.20.0/24=== ...82.9.102.84===?: [Tunnel Disconnected] grpips1 instance with peer 82.9.102.84 {isakmp=#0/ipsec=#0}
2017-07-02, 07:59:53 VPN Log [grpips1][12] 10.0.20.0/24=== ...82.9.102.84===? #18: [Tunnel Authorize Fail] no acceptable Oakley Transform
2017-07-02, 07:59:53 VPN Log [grpips1][12] 10.0.20.0/24=== ...82.9.102.84===? #18: [Tunnel Authorize Fail] CAST_CBC is not enabled for this connection. Attribute OAKLEY_HASH_ALGORITHM
2017-07-02, 07:59:53 VPN Log [grpips1][12] 10.0.20.0/24=== ...82.9.102.84===? #18: [Tunnel Authorize Fail] DES_CBC is not enabled for this connection. Attribute OAKLEY_HASH_ALGORITHM
2017-07-02, 07:59:53 VPN Log [grpips1][12] 10.0.20.0/24=== ...82.9.102.84===? #18: [Tunnel Authorize Fail] MODP_2048 is not enabled for this connection. Attribute OAKLEY_GROUP_DESCRIPTION
2017-07-02, 07:59:53 VPN Log [grpips1][12] 10.0.20.0/24=== ...82.9.102.84===? #18: [Tunnel Authorize Fail] RC5_R16_B64_CBC is not enabled for this connection. Attribute OAKLEY_HASH_ALGORITHM
I also notice that we are using group VPN access , so this should allow multiple users to access the VPN under that group , but i'm finding my self hitting the DISCONNECT icon on the VPN group to allow users to reconnect .
Example :
  The next log shows the user disconnected .
VPN Log [grpips1][16] 10.0.20.0/24=== ...82.69.23.111===172.16.100.102/32: [Tunnel Disconnected] grpips1 instance with peer 82.69.23.111 {isakmp=#0/ipsec=#0}
but the GUI shows him still connected.
Easy VPN 172.16.100.102 306964grpips1=up
Manually hitting the vpn disconnect Button in the GUI , clears the tunnel . And allows others to connect.
Any further help would much be appreciated.
