RV320 ignoring client VPN connection
VonHop
I've recently had to do a factory reset on my RV320 router. I'm trying to setup VPN client-to-gateway connection again. I've tried my previous configuration for using Shrewsoft VPN and even tried following setup for Greenbow VPN as well. Neither client is able to get past phase 1 setup.
I followed this video for Greenbow setup starting at the 4:00 mark: https://www.youtube.com/watch?v=MtvpESCYnrk
I've attached my configuration for it.
Looking at the logs on the router I see the connection is coming in, but then the RV320 seems to just ignore it and VPN doesn't pick up the connection on port 500:
2024-02-23, 08:25:36 ALLOW UDP 47.XXX.XXX.XXX:500 -> 76.XXX.XXX.XXX:500 on eth1
2024-02-23, 08:25:31 ALLOW UDP 47.XXX.XXX.XXX:500 -> 76.XXX.XXX.XXX:500 on eth1
2024-02-23, 08:25:26 ALLOW UDP 47.XXX.XXX.XXX:500 -> 76.XXX.XXX.XXX:500 on eth1
I have all logging turned on, but this is the only thing that shows up in the logs. Any idea on what I'm missing here?
balaji.bandi
VonHop
That is pretty similar to what I had to do, although the RV340 has more options than the RV320. Nothing stood out to be missing from my setup
