10-09-2017 10:10 AM - edited 03-21-2019 10:56 AM
I have a RV320 and have set up Some Vlans.
Vlan 1 is untagged on all ports, and all other vlans are Tagged on each port.
From Wireless Access Points connected, I can connect to each ssid and each one provides the appropriate DHCP (i.e. 192.168.1.x for the Vlan 1 and 192.168.20.x for vlan 20).
I have ensured that Inter Vlan Routing is disabled for each vlan and port, however I can still ping to and from separate VLans... any ideas?
10-09-2017 02:49 PM
Why not add an ACL to block inter VLAN access.
10-10-2017 11:08 AM
That solution did cross my mind, but I’m afraid after looking at the options to set that ACL up, I couldn’t make head nor tail of how to go about doing that.
would you be able to help me out with step by step instructions to do that?
thanks.
10-10-2017 08:46 PM
Add your guess VLAN and deny access to the rest of your network. You should be able to do it in a couple of statements.
12-20-2017 11:23 PM
Hi!
Did you solved your problem and managed to block traffic between VLAN?
I have a similar problem on RV345. I have several VLAN and although some have switched off Inter Vlan Routing, the devices between VLANs are visible.
If you've been able to do something about it, please share this knowledge.
Thank you!!
