RV320 inter VLAN routing not working
sistemasadm
Hi, I'm from Argentina and I can't get inter vlan routing
Please can you help me
PID VID: RV320-K9 V01
Firmware: v1.5.1.13 (2020-10-27, 13:37:43)
Working Mode: Gateway
VLAN Membership
VLAN: Enable
VLAN Table
                                 |            DHCP Setup                              |
ID | Routing |LAN1|LAN2|LAN3|LAN4|    IP    | Subnet Mask   | Start      | End        |
 1 | Enable  | U  | T  | T  | T  | 10.0.0.1 | 255.255.255.0 | 10.0.0.100 | 10.0.0.149 |
 2 | Enable  | T  | U  | E  | E  | 10.0.1.1 | 255.255.255.0 | 10.0.1.100 | 10.0.1.149 |
 3 | Enable  | T  | E  | U  | E  | 10.0.2.1 | 255.255.255.0 | 10.0.2.100 | 10.0.2.149 |
 4 | Enable  | T  | E  | E  | U  | 10.0.3.1 | 255.255.255.0 | 10.0.3.100 | 10.0.3.149 |
U -> Untagged | T -> Tagged | e -> Excluded
Need:
Devices on VLAN 1 can see devices on VLANs 2, 3, and 4
Devices on VLAN 2 can see devices on VLAN 2
Devices on VLAN 3 can see devices on VLAN 3
Devices on VLAN 4 can see devices on VLAN 4
Thank you
Hi @sistemasadm
RV320 is a router, this means, if you create two interfaces vlan on the router, intervlan routing should work automatically. But, in order to accomplish what you need, you need to use Access List. Take a look on this video and let me know. This is for RV34X but must apply to yours also.
https://www.youtube.com/watch?v=93OnQI8ToGo
Hi @sistemasadm
##- Flavio Miranda, your contribution was very helpful for me. Thank you very much, regards, sistemasadm -##
You are welcome. Thanks for rating.
