11-11-2016 05:14 AM
HI all,
Wonder if you might be able to help me figure this issue out. I chose the Cisco RV320 since it is Dual WAN, SPI firewall and generally a pretty solid product.
However I am recently facing an issue where I cannot configure: IGMP, IGMP Snooping, or being able to play any multicast streams.
Does anyone know if the rv320 can be configured to do this? at the moment I cannot find any setting anywhere to do with IGMP, and I am amazed that a professional router like this has no option for it.
Thanks in advance.
12-15-2016 04:30 PM
There are no IGMP settings available on the RV320 in this unit you only have Multicast Pass Through Enable/Disable checkbox which will either make the router pass through the multicast packets or not.
Cheers
-Gerald
01-09-2019 01:33 PM
Where in the menuing system is the setting for Multicast Passthrough?
01-16-2019 01:21 PM
Not sure if it's exactly the same on the 320, but the 325 it's under Firewall->General->Multicast Pass Through
