RV320 Problem Create 4th DHCP
corrado_home
I have a problem creating a 4th IP interface with a DHCP server and a different vlan.
Then in sequence I performed the following steps:
- Created the new vlan (id 20) [Menu: Port Management / VLAN Membership]
- Created a new IP Interface [Menu: Setup / Network]
This is the error that appears.
If instead I delete the IP interface created previously (192.168.20.250) and try to create the new DHCP interface (with the same parameters), the preceding error does not appear, but the DHCP profile is not created.
After press "Save"
Firmware Version: v1.3.2.02 (2016-09-23, 15:17:06)
2 Accepted Solutions
Here you go, I've configured on v1.4.2.17. If your FW is lower, router may be back to default.
Actually the router had strange behavior, so I tried to factory reset and I reconfigured everything again, without using the import of the configuration, and I finally solved.
Thanks anyway for your help.
Ami Xiao
You could follow below steps to meet your requirement.
  1. goto DHCP setup page and choose the VLAN20 then chang the subnet to 192.168.20.x/24
Thank you for your answer and sorry for the late reply, but I followed your instructions and the result is the same as shown in the last image.
Do you have configurations with more than three DHCP IP servers?
Would you be able to replicate my situation on one of your test devices?
So, the configuration to be replicated is as follows:
VLAN 1 DHCP 192.168.255.250
VLAN 2 DHCP 192.168.2.250
VLAN 20 DHCP 192.168.20.250
VLAN 200 DHCP 192.168.200.250
