RV320 / RV325 problem upgrade firmware 1.2.1.13
Last night I made the upgrade of two RV's (one RV320 and one RV325) in two different offices of the version 1.1.1.19 to 1.2.1.13 version without deleting any configuration. After the RV restarts automatically the connection to the Internet is lost.
I did a factory restoration with version 1.2.1.13 and then backed loaded configuration and did not work, the internet connection was lost.
I have to reconfigure step by step with this new version 1.2.1.13?
I hope some body help me, Thanks!
You might want to consider a downgrade to 1.1.1.19, load the config file (assuming you have one for this version), upgrade 1.2.1.13 and backup the config once upgraded.
Thanks but the config file must work after the upgrade. Im working now re-configuring the RV with the new 1.2.1.13 firmware
I agree - it should work.
But since it isn't, the suggested procedure might be quicker then reconfiguring things from scratch.
