07-18-2017 11:30 AM
Here is the problem, and I am open to any attempts at a solution. This is on a RV320.
Have a customer using Load Balancing with two different service providers for their site.
They do work with the state and various banks, who are balking at seeing two different IPs coming from the same location.
Is there a way to set (ideally) domain traffic for a particular domain name (big entities so no specific IPs) to use a particular WAN port so all traffic is consistently addressed?
Alternately, is there a way to segregate a specific port to only use one WAN? Less perfect, but gets the job done.
As stated, whatever else comes to mind that would do the trick is appreciated. Thank you.
Solved! Go to Solution.
08-02-2017 11:43 AM
Good Afternoon,
Effectively you are able to segregate or allow traffic to go to one specific WAN either WAN1/WAN2 however the only option is by IP address or subnets. Please see attachment.
Regards.
08-02-2017 11:43 AM
