RV320 Unstable and a bit confused
aje000001
We have 2 Cisco RV320 Routers connected through MPLS, and everything is working ok but;
1. If we upgrade the firmware (currently is v1.1.1.06) the router become unstable and within 1-5 days it simply freezes and require a manual reboot (unplug), after that bitter experience we stay in v1.1.1.06 with the limitation that gives us (e.g no DHCP on our guest VLAN)
2. anyway we are currently installing some new phone equipment and we therefor need to open som port in the firewall and make a port translation, however my concern here is, even though i have made a rule that only a given range is allowed to be accessed a server, it is every ip from the WAN port that is allowed (see attached config).
What i want to do is:
VOIM1 [8083]WAN1193.89.189.240 ~ 193.89.189.255192.168.101.51 ~ 192.168.101.51
but because i have a port translation 8083->80 every IP can do this, am i missing something?
ken4cisco
Not sure if you have figured out yet. Add a Access Table Rule Add a "Deny" "all" rule right after your allow rule. Like.. Priority #4 Deny Service VOIM1 [8083] Source Interface WAN1 Source Any Destination Any Always
