RV320 USB 3G/4G without NAT ?
NISITNETC
Hello !
Can I configure the RV320 with an USB 3G/4G Modem on the WAN Side without getting hide behind the public IP ?
My LTE Provider will push an public (unnated) IPv4 to the USB 3G/4G Modem. I will configure a public IPv4 Network on the LAN side. This public IPv4 Network will be routed via the public IPv4 on the USB 3G/4G Modem. In case of an Hide-NAT my "inside" public IPv4 Adresses can't be used "normal". Is it possible to use the USB 3/4G only routed ? Any Experiences from the community about that ?
Greetings
NISITNETC
NISITNETC
Folks,
no - it's not possible with this hardware. Figured it out month ago. Cisco has NAT with all known LTE Hardware and it can't work disabled. Solution with other hardware is possible: fixed IP adress on SIM Card with routed IPv4 public network works fine ...
NISITNETC
