RV320 VLAN Configuration for WAN
lavi44
Currently I am trying to configure a Cisco RV320 as a gateway. Using the WAN1 port to connect to the ISP (fibre optic). WAN port 2 is disabled. However, my ISP requires VLAN6 to be configured for internet connection (IPTV and VOIP are not required). I've read several posts that said I can't configure VLAN's on the WAN ports through the GUI. But, I was wondering if there is a way to set this up through SSH. The RV320 is running the lastest (03/18) firmware.
balaji.bandi
You are right, this is not possible due to limitation,
check this thread.
https://community.cisco.com/t5/small-business-routers/rv320-vlan-on-wan-port/td-p/2577720
BB
