RV320 VPN Remote Group.
petreski1
how can i add more than 1 ip range with specific subnet int the Remote Group.
We need to access different network on the peer side like :
10.0.1.0
192.168.1.0
172.16.5.0
the peer don't accept multiple connection.
thanks for your help
Toni.
ruwyatt
The RV320/RV325 will only allow one subnet per IKE policy. You may be able to supernet the remote security group but that probably is not the best idea if the subnets are not at least somewhat contiguous.
.:|:.:|:. CISCO | Russ Wyatt | Network Engineer | Cisco Technical Support |
