RV042 browser certificate errors when logging into web-based gui
newkansan
I have set the RV042 up for QuickVPN access.  The router config recommends turning HTTPS on in the firewall when using QuickVPN.  The side effect to this is any web browser throws me certificate errors and warns me not to continue logging in to the router's config.  How do I fix this so the browser does not throw these messages?
Router is Linksys-branded, using latest firmware for this hardware (1.3.13.02-tm)
Hello Tim,
Looking into this issue deeper it is due to the certificate being issued to cisco.com domain which you don't own. And when you connect to your router most likely with your own domain name or ip address it compares that information with the information stored in the certificate. Since it will never match it through's an error. The RV0xx series routers are not able to install 3rd Party certificates, so this will not be able to be resolved in their current release. I am not aware of any decision to change the code to resolve this issue. The RV220W and SA500 series routers do have the ability to install a third party certificate. The SA is the only other model that has the ability in the Small Business line to do dual WAN.
Cisco Small Business Support Center
Randy Manthey
CCNA, CCNA - Security
14 Replies 14
rocater
Level 3
Level 3
Hello Tim,
When using HTTPS with the RV042, the router will use a self-signed certificate. Most web-browsers will advise against going to any webpage with a self-signed cert. If you would like to avoid this, you can add the router's address to your browser's trusted list.
Hi Robert,
I went into Internet Options->Security Tab->Trusted Sites and added the router's IP address, but when I navigate to said IP in IE9, I still get the warning.  As a trouble-shooting step, I rebooted and tried again, but still no luck.
It seems that if I were to import the cert into Internet Options->Content->Certificates, that would alleviate the problem, but I don't know how to obtain the RV042's self-signed cert into a format that I could import into IE9.  Any suggestions?
Hello Tim,
Since Cisco.com is not a trusted root authority. To install the certificate you will have to added it to your trusted root authority folder. There should be an option when adding the certificate to browse to the appropriate folder.
Randy Manthey
Thanks, Randy.
I still do not know where to find the Cisco.com certificate.  The Certificate Import Wizard in Internet Options does allow me to browse to other folders, but I don't know where to browse to in order to import the Cisco certificate.  It looks like the Certificate Import Wizard accepts only certain file extensions: .cer, .crt, .pfx, .p12, .stl, .crl, .sst, .spc, and .p7b.
Same problem on my rv042. I had to downgrade the V1 to get around this problem. But the V3 rv042 allways brings up this requester.
Can I get a firmware without this "feature" ? I use remote administration from many different browsers (smartphone), so this is very annoying without a real security benefit.
Tim,
Top of the IE page you should have a red broken lock looking thing right click on the icon and choose to view the certificate from there you can install it.
Randy Manthey
Thank you, Randy.  I found it.  Only problem is it didn't work.  I imported the cert into Trusted Root Certification Authorities (I can see it in there, so I know the import took place), but still get the error when connecting to the router through IE9.  It says:
There is a problem with this website's security  certificate.
The security  certificate presented by this website was issued for a different website's  address.
Security certificate  problems may indicate an attempt to fool you or intercept any data you send to  the server.
We recommend that you close this webpage and do not  continue to this website.
Recommended iconClick here to close this  webpage.
Not recommended iconContinue to this website (not  recommended).
The security certificated presented by this website was issued for a different website's address.
Hello Tim,
Randy Manthey
Thanks, Randy.  It looks like this feature was introduced in the latest firmware, as I did not have this problem prior to flashing about a month ago.  It's more annoying than anything else, so I guess I just have to live with it.
Cheers,
Tim
But what should I do with the V3 of the Rv042 ?
Can I also downgrade to get rid of this feature ?
BTW: When visiting this forum, I also get complaints about invalid certificates mcctags.cisco.com.
          I would not expect this kind of warnings in a cisco-site.
RJStuart5012
I too am having the same problem with my RV042 routers.  I have 5 of them installed on different domains.  The oldest one has firmware 1.3.8.2, and that is the only one that does not present this certificate error.  Any other router has firmware 1.3.12.6 or older.  I must have HTTPS enabled in order to use the VPN client so it is a real pain.  You would think that Cisco would have a fix for this problem.
Same problem here, any solution????
eyenstein
Hi Randy,
This issue with the RV042G not accepting 3rd party certificates is still present in the v4.2.3.06 firmware. Chrome and other browsers are now refusing to connect to the router without an override option as allowed previously, giving the error "Server has a weak ephemeral Diffie-Hellman public key". This is no longer a nuisance, but is now defect status and needs to be addressed as it has been in Cisco's other products. Is there any word on when this might happen?
Doug
Hi Doug,
I started a new discussion https://supportforums.cisco.com/discussion/12600331/rv042-w-firmware-42306-server-has-weak-ephemeral-dillie-heffman-public-key. Agree that this has become a defect and hope it's addressed quickly.
John
