RV325 EasyVPN is not working for Android when using firmware v1.3.2.02
edward.chan2015
Beginner
Beginner
EasyVPN is not working using Android after upgrade to v1.3.2.02.  No problem when I fall back yo use version 1.3.1.12 using the same settings.
Here is the log for your ref:
2016-12-18, 10:48:43 VPN Log [grpips1][1] 0.0.0.0/0=== ...14.0.224.159===? #1: [Tunnel Authorize Fail] RC5_R16_B64_CBC is not enabled for this connection. Attribute OAKLEY_HASH_ALGORITHM
2016-12-18, 10:48:43 VPN Log [grpips1][1] 0.0.0.0/0=== ...14.0.224.159===? #1: [Tunnel Authorize Fail] received Hash Payload does not match computed value
2016-12-18, 10:48:43 VPN Log [grpips1][1] 0.0.0.0/0=== ...14.0.224.159===? #1: [Tunnel Established] ISAKMP SA established
2016-12-18, 10:48:43 ALLOW UDP 14.0.224.159:57385 -> 1.36.192.81:4500 on eth1
2016-12-18, 10:48:43 VPN Log [grpips1][1] 0.0.0.0/0=== ...14.0.224.159===? #1: [Tunnel Established] received XAUTH ack, established
When it is working, log should looks like:
2016-12-18, 10:40:09 VPN Log [grpips0][2] 192.168.111.0/24=== ...14.0.224.159===? #3: [Tunnel Authorize Fail] RC5_R16_B64_CBC is not enabled for this connection. Attribute OAKLEY_HASH_ALGORITHM
2016-12-18, 10:40:09 VPN Log [grpips0][2] 192.168.111.0/24=== ...14.0.224.159===? #3: [Tunnel Authorize Fail] received Hash Payload does not match computed value
2016-12-18, 10:40:09 VPN Log [grpips0][2] 192.168.111.0/24=== ...14.0.224.159===? #3: [Tunnel Established] ISAKMP SA established
2016-12-18, 10:40:10 VPN Log [grpips0][2] 192.168.111.0/24=== ...14.0.224.159===? #3: [Tunnel Established] received XAUTH ack, established
2016-12-18, 10:40:10 VPN Log [grpips0][2] 0.0.0.0/0=== ...14.0.224.159===172.18.100.3/32 #3: [Tunnel Established] sent ModeCfg reply, established
2016-12-18, 10:40:11 VPN Log [grpips0]: cmd=up-client peer=14.0.224.159 peer_client=172.18.100.3/32 peer_client_net=172.18.100.3 peer_client_mask=255.255.255.255
2016-12-18, 10:40:11 VPN Log ip route add 172.18.100.3/32 via 1.36.192.252 dev eth1 metric 35
0 Replies 0
Recognize Your Peers
