RV325 port forwarding to /26 subnet can't be configured
scottdcarson
I have an RV325, firmware v1.1.1.06.   One of my vlans is a /26 subnet that doesn't start at 0; it contains addresses 64-127 (with the router at 65).  I'm trying to configure an external port forward from port 80 to .66 (in this case, 192.168.4.66).  But when I do, I get the message "Private IP address should be under 192.168.4.1-62!"
I can trick the UI into allowing me to set this up by temporarily changing the vlan to a /25, entering the forwarding rule, and changing it back to a /26.  But then, what's my confidence that the forwarding will take place?   And, once the router's in production, this idea becomes considerably less attractive. Yes, I could set up a lab and test this, but isn't that Cisco's job?
This seems like a flat out bug to me.  Has anyone else had a similar experience and/or figured out a way around it?
I'm attaching a couple of relevant screen shots.  Thanks, my friends.
Here's the subnet setup for VLAN 25.
Network/Subnet Setup
And here's the error message I get when trying to forward a port to that subnet.
Error message trying to forward.
Mehdi Boukraa
Hi Scott,
My name is Mehdi from Cisco Technical Support, please can you try to configure this rule (port forwarding for Port 80 ) from Port Address Translation and not from Forwarding, and you don't need to translate the port (if not needed) just from drop down menu select HTTP (TCP/80-80) to the server 192.168.4.66
Please rate this post or marked as answered to help other Cisco Customers
Greetings
Mehdi
