09-28-2015 07:40 PM
The rv325 seems to spontaneously be rebooting. I've only had it a couple of weeks. The only thing I can see is in the system log (below). Is there more in the way of diagnostics that can be enabled to track reboot cause? I have now enabled the kernel log, but that is already reporting random upnp traffic, so I guess that will quickly fill up.
2015-09-22, 19:00:00 | System Log | RV325 : System is up |
2015-09-27, 13:28:35 | System Log | RV325 : System is up |
01-04-2016 08:12 PM
This is still happening. Anyone have a solution? There have been periods where this happens more frequently. The problem now is that it will not get an IP address from the modem. I have tried setting a static IP, but even then if the router crashes and reboots the WAN IP address is 0.0.0.0 (even though if I go to network settings and check the setting the static WAN IP is still configured). The network behind the RV325 has now been completely unreliable for 3mos now.
01-27-2023 05:15 PM
(Possibly related, but not sure) Since I re-flashed the latest firmware I am now getting random reboots 2 to 5 times a day. The log file below gives no hint as to what caused it and the snippet below just repeats for every reboot.
I have measured and o-scoped all of the internal supplies as well as the 12V input, all are correct and free of noise.
I pointed a security camera at it and wrote a ping test monitor to notify me when it goes offline. Looked at the camera footage at the time stamp of failure and the LEDs go straight from normal operation to hard reset sequence. None of the other devices on the same UPS show any reaction, so power glitches can be eliminated.
Any thoughts? Is it possible to re-flash the FW with the same version again in case of a possible weak bit?
2023-01-27, 17:03:19 User Log User cisco login success from 192.168.0.1
2023-01-27, 16:57:43 Kernel kernel: add new: cnt[17] learn mac[UU-VV-WW-XX-YY-ZZ], ip[192.168.0.118], idx[6c]
2023-01-27, 16:57:43 Kernel kernel: add new: cnt[16] learn mac[UU-VV-WW-XX-YY-ZZ], ip[192.168.0.23], idx[f9]
2023-01-27, 12:50:44 Kernel kernel: add new: cnt[15] learn mac[UU-VV-WW-XX-YY-ZZ], ip[192.168.0.31], idx[9d]
2023-01-27, 12:36:16 Kernel kernel: add new: cnt[14] learn mac[UU-VV-WW-XX-YY-ZZ], ip[192.168.0.82], idx[5a]
2023-01-27, 12:33:02 Kernel kernel: add new: cnt[13] learn mac[UU-VV-WW-XX-YY-ZZ], ip[192.168.0.13], idx[44]
2023-01-27, 12:22:50 Kernel kernel: add new: cnt[12] learn mac[UU-VV-WW-XX-YY-ZZ], ip[192.168.0.30], idx[97]
2023-01-27, 12:21:52 Kernel kernel: add new: cnt[11] learn mac[UU-VV-WW-XX-YY-ZZ], ip[192.168.0.10], idx[38]
2023-01-27, 12:21:20 Kernel kernel: add new: cnt[10] learn mac[UU-VV-WW-XX-YY-ZZ], ip[192.168.0.5], idx[1d]
2023-01-27, 12:21:19 Kernel kernel: add new: cnt[9] learn mac[UU-VV-WW-XX-YY-ZZ], ip[192.168.0.115], idx[78]
2023-01-27, 12:21:12 Kernel kernel: ip[0.0.0.0] mask[0.0.0.0]
2023-01-27, 12:21:12 Kernel kernel: ip[174.51.190.23] mask[0.0.0.0]
2023-01-27, 12:21:12 Kernel kernel: [eth0] lanip=192.168.0.1, mask=255.255.255.0
2023-01-27, 12:21:03 Kernel kernel: add new: cnt[8] learn mac[UU-VV-WW-XX-YY-ZZ], ip[192.168.0.14], idx[a1]
2023-01-27, 12:20:45 Kernel kernel: add new: cnt[7] learn mac[UU-VV-WW-XX-YY-ZZ], ip[192.168.0.11], idx[ad]
2023-01-27, 12:20:33 Kernel kernel: add new: cnt[6] learn mac[UU-VV-WW-XX-YY-ZZ], ip[192.168.0.26], idx[b2]
2023-01-27, 12:20:30 Kernel kernel: ip[0.0.0.0] mask[0.0.0.0]
2023-01-27, 12:20:30 Kernel kernel: ip[174.51.190.23] mask[0.0.0.0]
2023-01-27, 12:20:30 Kernel kernel: [eth0] lanip=192.168.0.1, mask=255.255.255.0
2023-01-27, 12:20:29 Kernel kernel: ip[0.0.0.0] mask[0.0.0.0]
2023-01-27, 12:20:29 Kernel kernel: ip[174.51.190.23] mask[0.0.0.0]
2023-01-27, 12:20:29 Kernel kernel: [eth0] lanip=192.168.0.1, mask=255.255.255.0
2023-01-27, 12:20:27 Kernel kernel: add new: cnt[4] learn mac[UU-VV-WW-XX-YY-ZZ], ip[192.168.0.3], idx[3d]
2023-01-27, 12:20:26 Kernel kernel: add new: cnt[3] learn mac[UU-VV-WW-XX-YY-ZZ], ip[192.168.0.27], idx[0]
2023-01-27, 12:20:24 Kernel kernel: add new: cnt[2] learn mac[UU-VV-WW-XX-YY-ZZ], ip[192.168.0.2], idx[9c]
2023-01-27, 12:20:16 Kernel kernel: add new: cnt[1] learn mac[UU-VV-WW-XX-YY-ZZ], ip[192.168.0.6], idx[26]
2023-01-27, 12:20:15 Kernel kernel: ip[0.0.0.0] mask[0.0.0.0]
2023-01-27, 12:20:15 Kernel kernel: [eth0] lanip=192.168.0.1, mask=255.255.255.0
2023-01-27, 12:20:09 Kernel kernel: Start Check Reg ( 0, 16, 0 )
2023-01-27, 12:20:09 Kernel kernel: WAN [1] UP
2023-01-27, 12:20:09 Kernel kernel: SIOC_GET_SWITCH_MINOR_TYPE: switch_minor_type[0]
2023-01-27, 12:20:09 Kernel kernel: SIOC_GET_SWITCH_TYPE: switch_type[325]
2023-01-27, 12:20:09 Kernel kernel: Set GPIO (SW_RST:1), (DMZ:5), (CS_LAN:2), (CS_WAN:2), (CS_MAC:2), (CS_PHY:2), (SERI_CLK:3), (SW_DAT:4) OUT
2023-01-27, 12:20:09 Kernel kernel: Set GPIO(RESET_BT:6) IN
2023-01-27, 12:20:09 Kernel kernel: Switch driver starting...
2023-01-27, 12:20:09 Kernel kernel: nk: Register the control device, /dev/url
2023-01-27, 12:20:09 Kernel kernel: used_num_smi ( 1 )
2023-01-27, 12:20:09 Kernel kernel: vlan_num_group ( 14 )
2023-01-27, 12:20:09 Kernel kernel: used_num_mii ( 1 )
2023-01-27, 12:20:09 Kernel kernel: dev mii ( 0, 0, 0, 0 )
2023-01-27, 12:20:09 Kernel kernel: ipd_prt_txclk ( 12, 0, 0, 0 )
2023-01-27, 12:20:09 Kernel kernel: ipd_prt_rxclk ( 12, 0, 0, 0 )
2023-01-27, 12:20:09 Kernel kernel: ipd_prt_spd ( 1000, 0, 0, 0 )
2023-01-27, 12:20:09 Kernel kernel: lan[14], wan[2], dmz[0], usb[0], max_session[30000], hash[8192],
2023-01-27, 12:20:09 Kernel kernel: Init model[325-0] system information:
2023-01-27, 12:19:53 System Log Firmware Version : v1.5.1.13
2023-01-27, 12:19:53 System Log router6e092c : System is up
