Now try for hours to set up a VPN between a RV325 ans RV082 (Gateway-Gateway).
PPTP to RV325 works.... but that's not an option.
The problem is NOT the RV082.
For a test I set up a RV082 instead of a RV325. VPN worked immediately.
Only with the RV325 it does not work. Latest firmware is installed.
A VPN (Gateway-Gateway) with an RV325 should be as simple as the RV082?
I hope someone can help
