RV340 hang when using VPN site-to-site
Catalin Burla
Hi.
For +5 years I manage a farm of various RV routers with VPN site-to-site. Around 700 locations connected to HQ , at the beginning with Linksys routers then under Cisco brand. RV042, RV042G , RV320, RV082, RV016, all of then are online 24/7/365.
With every launch dual-wan+vpn device I replaced few working routers and become more or less a "tester", eager to get the increased performance and stability.
RV320 was released with a broken firmware regarding VPN connections: if using more than 2-3 VPN tunnels suddenly hangs. I opened a case and it took more than 6 months to see a working firmware while I put my infrastructure at Cisco disposal to investigate and test.
When RV340 was announced I was glad, the 100 Mbps VPN barrier was exceeded. I ordered 5 RV340 and 3 RV345, waited  3- 4 weeks for delivery and.... RV340 has also a broken firmware regarding VPN connections: it suddenly hangs, down not respond to ping, does not load interface , no traffic, nothing. It can work for 1 day to 10 days, but for sure it will hang. For more than 2 months I still insist using RV340, but I think next step is RMA . It's the same behavior that RV320 had ! I am using RV340 only for 9 VPN  tunnels over MPLS lines, no other traffic thru this unit. All 9 MPLS connections cumulated are about 100 Mbps and most important router is freezing during working hours BUT also on night hours when traffic in ZERO.
I somehow contacted Cisco Romania, they told me that I am not the only one complaining.
I tried to open a case by phone on Cisco, the guy asked for service contract and I don't have one.
If somebody else run into same problems please share .
Best regards,
34 Replies 34
Hi Martin
thx for the quick response.
I don´t have any webfilter/AV etc enabled. The license also shows: Evaluation Mode (78 days, 21 hours, 2 minutes, 11 seconds remaining)
I´m not planning to use this features.
I will try to capture WAN Traffic when the issue accures. I have enabled debug logging and sent to a syslog server. So if this log´s also help I can provide them.
Greets
Andreas
Hi Martin
Today I had the issue again. For about 7 minutes issues with reaching wesbite on the outside.
I figured out that the connection issues seem to be mainly with https Port 443 - other ports like 25 worked.
I also managed to do a package capture and see many errors with remote tcp port 443 - so there seems to be a problem.
Also the Packet Errors on WAN port in the RV340 GUI raised up from 530 to 2903 on WAN1 Interface.
I will now try to open a support case - I have to add that I´m not a business customer - I use it privatly at my home.
Greets
Andreas
Even the TAC Case is open, log files and debug info sent, not much is happening from cisco side.
Today the RV340 crashed completely - with rebooting itself.
Info from the log:
2021-01-26 21:43:14 Kernel.Alert 11.12.xx.xx 1 2021-01-26T21:43:14+01:00 home kernel - - [meta sequenceId="107186"] [388844.382880] Unable to handle kernel NULL pointer dereference at virtual address 000000f5
2021-01-26 21:43:14 Kernel.Alert 11.12.xx.xx 1 2021-01-26T21:43:14+01:00 home kernel - - [meta sequenceId="107187"] [388844.382900] pgd = bd84c000
2021-01-26 21:43:14 Kernel.Alert 11.12.xx.xx 1 2021-01-26T21:43:14+01:00 home kernel - - [meta sequenceId="107188"] [388844.382908] [000000f5] *pgd=3d88a831, *pte=00000000, *ppte=00000000
2021-01-26 21:43:14 Kernel.Emerg 11.12.xx.xx 1 2021-01-26T21:43:14+01:00 home kernel - - [meta sequenceId="107189"] [388844.382933] Internal error: Oops: 17 [#1] SMP ARM
I think this RV340 is really a bad choice!!
budwlkr2888
I haven't been on here for quite a while but have updated firmware on all of our RV340 routers to Firmware Ver 1.0.3.16 and all VPN Client to Site & Site to Site have been stable for quite some time.
Bud
I've done the same. But, I'm now unstable.
