RV340 - How to config QoS for VLAN Voice Traffic
WITnet
Need some help setting up QoS for voice VLAN.
I’m familiar with the RV320 but configuration has changed in the RV340.
Honestly, a better explanation of the QoS options in the manual would be very helpful.
 Setup
I have (2) VLANs, VLAN 1 for Data and VLAN 20 for Voice.
(PC’s & Printers on VLAN 1, IP Phones on VLAN 20)
Simply put, I’d like to give all VLAN 20 traffic priority over VLAN 1 traffic.
Just confused between options between Classes, Queuing, Policing and Bandwidth Management and in what combination. (Running Firmware: 1.0.01.18)
Our ISP connection is 100Mbps Down & 10Mbps Up.
Any clarification would be greatly appreciated.
Thierry_TDG
Running current fw 1.0.2.16
Same situation, same explanations needed :)
Moreover, what about applying QOS on IPSec S2S tunnels ?
Thanks.
