RV340 K9 Router SSL VPN Issue
gaurkamlesh
Earlier my SSL VPN works fine but when i have reconfigured same SSL VPN setting in my RV340 K9 router after router reset it is not working. I took the backup of configuration earlier and same i have uploaded on the router but still SSL VPN not working.
Any Clue?
Sujoy Paria
Are you able to see any log on the RV340 router when you are tying to connect the SSL VPN from the client side?
You may refer the video https://www.youtube.com/watch?v=DnP7-lkud7o and verify the SSL VPN settings once on the RV340.
