RV340 WAN2 showing up even without connection
eldercarrilho
The WAN2 port led indicator on my Cisco RV340 is showing up, even without any cable connected. On Port Traffic, I can see some TX traffic and some packet errors. On Port Status, WAN2 is showing a 10Mb/half duplex speed, even if I forced to a 100Mb or 1000Mb setting. The firmware version is 1.0.03.26, router was set to default settings.
Anyone was faced this issue?
Thanks!
balaji.bandi
what port its connected other end ? if nothing connected may be bug, check disable from GUI is the status same ?
try changing speed on GUI and test --- as i mentioned depends on other side connection ?
what will be the outcome if you do same on WAN 1 ?
BB
Nothing is connected. I disabled WAN2 and changed the speed on GUI and nothing happens.
On WAN1, everything is working flawless.
Is this wan is dailer interface?
No, is a static IP connection.
Both ISP connections was working fine, I tested with a RV320. I discovered this issue after a momentary problem with our primary ISP, when I realized that failover function was not working.
