I have Cisco RV340 as router and a Ubiquiti Wireless access point. I want to separate different clients to their own VLANs and limit their connectivity between VLANs (e.g. not allowing IoT devices to communicate to other VLANs).
My wireless AP is currently connected to LAN1 in RV340. All connected wireless clients are in VLAN1 at the moment.
I can set static ip addresses for devices once they are part of VLAN1. If I create more VLANs and try to set static IP address to those it will not work. The device will still stay in VLAN1 even if I do that.
So the question is: what should I do to assign connected clients to their own VLANs and still allow the to connect to WAN? After I would be able to set the device into their own VLANs I should be able to limit their access to other VLANs by setting firewall rules. But as long they all stay in VLAN1 it is not possible.
Thanks.
