RV345 and Huawei E3372 USB Dongle Support
willyahm
Has anyone gotten the RV34X routers to work with an E3372 usb modem?
I have the my E3372h-153 flashed to stick mode from Hilink mode and have removed the SD-CARD / CD-ROM drives from the device using AT-commands, however the RV345 refuses to connect to the device.
It recognises the manufacturer as Huawei on the mobile networks configuration page and the RV32X routers have official support for them from Cisco
Is there a way to get these two to work together?
you can use below link to find recommended Modems. still you can try other devices and connect. if you can check the dongle with default state (without changing any AT commands) that will work most of the times.
https://www.cisco.com/c/dam/en/us/td/docs/routers/csbr/RV345/USB_Compatibility_Matrix/compatibility_matrix.pdf
*** Pls rate and mark solved all useful responses ***
Good Luck
Good luck
KB
