RV345 authentication failure
masc1
Every time I login to the webinterface to the RV345, I immediately get an Email showing this:
2022-07-24T20:03:45+01:00 <info>weblogin: pam_krb5(weblogin:auth): (user cisco) authentication failure
But there was no failure during login - everything worked fine on the first try! Has anyone the same issue?
kind regards
marce1000
            - Is the username 'cisco' ?
 M.
Yes, the user is 'cisco'
 - Try and or configure none default username , although it should probably not be logged as such, but in business context and security use 'private' usernames. Also consider using latest firmware , if applicable.
 M.
