11-03-2021 07:09 PM
Since receiving an automated firmware upgrade to 1.0.03.24 this week, all client-to-site VPN connection are failing on our RV345. The relevant parts of the logs (more can be provided if needed) appear to be:
info vpn charon: 10[IKE] PAM authentication has received the connection name 'c2s_vpn' error vpn charon: PAM no modules loaded for `s2s-vpn' service info vpn charon: 10[IKE] XAuth pam_authenticate for 'vpntest' failed: Permission denied
This occurs both with our Radius authenticated user group as well as a local user setup (per logs) to rule out a Radius issue. The obvious error is regarding a missing module for the 's2s-vpn' service, yet this is a 'c2s-vpn' tunnel. I can't find any reference to this error in search results or community posts, nor anything relevant in the release notes for this release, so any help would be appreciated.
11-04-2021 04:00 AM - edited 11-04-2021 04:06 AM
There seems to be an issue with New firmware 1.0.03.24 blocking traffic in general current configurations.
There is one person that did a reset after update and reconfigured but experienced anomalies.
New firmware 1.0.03.24 for rv340w - Cisco Community
11-04-2021 04:34 AM
- You may want to further escalate this problem :
https://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
M,
11-04-2021 07:16 AM - edited 11-04-2021 07:17 AM
Thanks for pointing me to this, I hadn't seen it. Good to know we're not alone with this.
Unfortunately, it looks like the only 'solution' presented there is to roll back to 1.0.3.22, which we were hoping to avoid. We'll hold off on doing that for as long as possible in the hope that an actual solution is found, otherwise will go with that and disable automated updates to avoid this. Although I'm not sure what we (and others seemingly) as supposed to do if a security release is issued in future.
11-04-2021 04:23 PM
UPDATE:
Reverting to 1.0.3.22 has resolved this. Thankfully we had a config backup from prior to the automated update, so we factory reset the device, installed/reverted the firmware, then imported the backup config (and disabled automated updates). VPN connections are working again as previously.
This means that we, along with others seemingly, cannot apply further updates to this device until this issue is resolved, rendering the further year of security updates on the device redundant currently. If would be good if someone from Cisco can log this as an issue.
11-04-2021 11:38 PM
...> If would be good if someone from Cisco can log this as an issue
The common practice is for customers to take action :
M
12-21-2021 02:53 AM
I also had to roll back to 1.0.3.21 (didn't try even the 1.0.3.22, went straight to 1.0.3.21 I had before). I had a perfectly working setup, but then Radius stopped working with the update to 1.0.3.24. I get these warnings in the log:
https://slack-files.com/T0BA8B8G1-F02REN1SWEP-858aee79c6
pptp: rc_read_config: can't open /etc/radiusclient/radiusclient.conf: No such file or directory
pptp: RADIUS: Can't read config file /etc/radiusclient/radiusclient.conf
Something clearly broke.
12-22-2021 12:04 PM
Yesterday I reached Cisco Support for 2 RV-340 with connectivity issues upgrade to .24. Send logs and configurations to Cisco for analisys. First response was "you should roll back to 1.0.03.22 or do an upgrade to 1.0.03.24 + factory reset + configure from start". I wasn´t pleased with those solutions so they scaled the issue to a sustaining enginner. They promised me 24/48 hs with a feedback.
01-31-2022 07:57 AM
I have the same problem with the latest version 1.0.03.26, I'll rollback to 1.0.03.22 where there is no problem... It looks like Cisco y releasing the upgrades without fixing the issues...
01-31-2022 08:15 AM
02-02-2022 08:23 AM
exactly, also tring with version 1.0.03.26 there is the same vpn issue....I'll rollback to 3.22....
02-07-2022 06:07 PM
I can confirm that 1.03.26 also screws up VPN authentication using both Cisco AnyConnect client and Baked in Cisco IPSec client backed into iOS and MacOS 12.2. Please get this fixed Cisco. It is the primary reason my business bought the router was the amount of VPN client options and AnyConnect.
02-07-2022 11:06 PM
>....Please get this fixed Cisco
FYI : https://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
M.
02-19-2022 12:23 PM
All,
I spoke to a support engineer
and have a case open. They are recommending upgrading to 1.03.26. Then doing a factory reset. Then MANUALY reconfiguring the router’s settings. I asked about restoring my config from .22 and he said there are differences and configuration changes so best approach is do a manual reconfigure. I am on the fence on doing it as it is time consuming and I am not if this will fix it the VPN issue? Obviously I will do a full backup again of my 1.03.22 setup to a PC and have both firmwares….for a roll back. Oh and the RV’s have been discontinued due to the chipset shortage. Supposedly a new model or two is in the pipeline.
04-25-2022 11:42 PM
Did you end up staying on .26 and reconfiguring from scratch? Did that resolve the issue?
