RV345 FIRMWARE ver bug on 1.0.03.22 with STATIC NAT "+" not available?
dmitritoch
We are trying to add a static NAT with admin account Screen Shot 2021-10-25 at 8.55.02 AM.png but add button isn't not clickable. It seems like UI gui bug.
Any suggestion for the work around
8 Replies 8
marce1000
  - Have you tried other browsers ?
 M.
nagrajk1969
How many total entries are already existing in the Static-NAT section?
I believe there is a limit to number of entries that is allowed....i think it is 30 or something....maybe less too, iam not able to recall now, but there is a limit, after which you cant add any more...
There are only 8 setup and if you delete you won't be able to add it back. I don't think it is a license limitation
Seems like a browser issue. Please check once from any other system and browser (Firefox, Google Chrome,etc.). You may reboot the router once and verify.
nagrajk1969
There is a bug in the GUI for sure....and its happened becos one or more of the local/lan "vlanX-interface" (in the same private-address-space/range used in atleast one of the existing static-nat rules) has been deleted
Add back the delete vlan-interface under LAN/vlan...and then after apply (click apply twice just to be sure), check in the static-nat page...it should be active again
The work around is to use xml, edit configuration and re upload again. Obviously, we tried all the browsers and I can guarantee this is the software bug. It is a bit disappointing that it was a while and it wasn't fixed with new firmware yet
nagrajk1969
check this out, and confirm that its a bug or not
Step-1: configure existing vlan1...
Step-2: In Firewall/Static-Nat page, add a entry for static-nat as below(approximately):
Assuming that the wan-ipadrr subnet is 55.55.55.x/24 on wan1 and the ipaddr on wan1 is configured as 55.55.55.21/24 for example
Private-Address-Start: 192.168.1.30
Public-Address: 55.55.55.30
Range: 5
Wan1
- apply and do a permanent save too
Step-3: Now configure another vlan2 for example with ipaddress as 192.168.2.1/24 on this RV router
Step-4: Now again in Firewall/Static-Nat page, add one more static nat rule as below:
Private-Address-Start: 192.168.2.52
Public-Address: 55.55.55.52
Range: 5
Wan1
Step-5: And now (maybe after doing a check if required that both the static nat rules or just the first one in the vlan1 subnet is working as expected), go to LAN/vlan page, AND delete vlan2 interface and do a Apply, and also a save too
Step-6: And then next, go to Firewall/Static-Nat page and you will observe that the page is grayed-out and now you cannot either add any new rule and nor can you edit any existing rules...(2 rules added earlier)
its a bug
the present workaround be is to once again add/configure vlan2 interface in same 192.168.2.1/24 subnet....and apply/save
- only then the Static-nat page becomes active again for adding/editing/updating
nagrajk1969
ok. Just to understand, when you say "edit configuration" in the xml-config-file, what exactly have you "edited/changed" in the config file?...before "re-upload"?...just want to know about this method...
thanks in advance
regards
