RV345 Static route inside LAN problem (RV325 was working)
michael.pammer
Hi Group,
It seems that a RV345 behaves differently than a RV325 with a static route.
Originally a Fortigate 50, then for a short period a Netgear one and later a Cisco RV 325 worked with basically the same Setting... RV345 doesnt...
Setup:
RV325 on WAN 1 via NAT connected to a cable modem… (fast Internet) ...
Inside, as RV325 is working as DHCP several PCs, Printers... addtional Server, NAS and so on... 192.168.1.1 till 200
Additional a second router connected to ADSL secure Network with static IP inside the LAN on 192.168.1.254
The second router should get / Transfer data only via it's own private secure Network seperated from the Internet , basically a secure ADSL Internet line… without Internet :-) So only packets to 2 IPs should be sent…. and guess backwards to the generating PCs...
As mentioned the RV325 and the previous routers managed that with a static route, so I expected it should work with the RV345 as well… but, changing over to the RV345 it does not work. Any ideas what I did wrong?
Metric also changed to 2 btw...
RV345 Firmware: Tested with 3 Versions, latest 1.0.02.16, 1.0.01.20, 1.0.01.16
After Firmwareupdate , reset to defaul, manually entered again...
Any ideas
Kind regards,
Michael
0 Replies 0
