RV345P sending out warnings
michael
Good evening,
My RV345P is flooding my syslog server with stuff like
   "sequenceId="55"] kernel[520263.051313] fp_netfilter_pre_routing: 6 callback suppressed
Can someone advise me on what this means and how to prevent this warning from happening?
Kind regards, Michael.
11 Replies 11
balaji.bandi
check is the device updated firmware, check full log what causing the issue.
if this is coming from outside, this is more of dos attack, so router not able to handle those time it get this error - just top of my head
once we get more log we can guide what causing this issue.
BB
Thanks for the swift reply.
1 - Yes, forgot to mention, the firmware is at the latest available version.
2 - Following the DoS scenario. Could it be the case that there is too much traffic generated internally (streaming, conferencing, ...) that is not handled well by this device? Thus resulting in this warning message.
chances are there high level, post full log and what kind of traffic you see or monitored ?
BB
These are literally my log entries
2021-01-25T16:20:33+01:00 kernel: [590765.820611] fp_netfilter_pre_routing: 2 callbacks suppressed
2021-01-25T16:19:33+01:00 kernel: [590705.726423] fp_netfilter_pre_routing: 2 callbacks suppressed
2021-01-25T16:15:10+01:00 kernel: [590441.933610] fp_netfilter_pre_routing: 4 callbacks suppressed
2021-01-25T16:12:32+01:00 kernel: [590284.598129] fp_netfilter_pre_routing: 2 callbacks suppressed
2021-01-25T16:10:32+01:00 kernel: [590164.317683] fp_netfilter_pre_routing: 2 callbacks suppressed
2021-01-25T16:10:07+01:00 kernel: [590139.790462] fp_netfilter_pre_routing: 2 callbacks suppressed
2021-01-25T16:08:32+01:00 kernel: [590044.048433] fp_netfilter_pre_routing: 2 callbacks suppressed
2021-01-25T16:06:31+01:00 kernel: [589923.513382] fp_netfilter_pre_routing: 14 callbacks suppressed
2021-01-25T16:06:12+01:00 kernel: [589904.318466] fp_netfilter_pre_routing: 20 callbacks suppressed
2021-01-25T16:06:06+01:00 kernel: [589898.423721] fp_netfilter_pre_routing: 6 callbacks suppressed
2021-01-25T16:00:30+01:00 kernel: [589562.305333] fp_netfilter_pre_routing: 14 callbacks suppressed
2021-01-25T15:59:57+01:00 kernel: [589529.619513] fp_netfilter_pre_routing: 2 callbacks suppressed
2021-01-25T15:54:59+01:00 kernel: [589231.059245] fp_netfilter_pre_routing: 2 callbacks suppressed
2021-01-25T15:53:58+01:00 kernel: [589170.805084] fp_netfilter_pre_routing: 2 callbacks suppressed
2021-01-25T15:49:58+01:00 kernel: [588930.102868] fp_netfilter_pre_routing: 4 callbacks suppressed
2021-01-25T15:49:35+01:00 kernel: [588907.061733] fp_netfilter_pre_routing: 2 callbacks suppressed
2021-01-25T15:47:27+01:00 kernel: [588779.655359] fp_netfilter_pre_routing: 2 callbacks suppressed
2021-01-25T15:45:57+01:00 kernel: [588689.354014] fp_netfilter_pre_routing: 2 callbacks suppressed
2021-01-25T15:44:57+01:00 kernel: [588629.177439] fp_netfilter_pre_routing: 2 callbacks suppressed
2021-01-25T15:44:45+01:00 kernel: [588617.102114] fp_netfilter_pre_routing: 2 callbacks suppressed
2021-01-25T15:40:56+01:00 kernel: [588388.386483] fp_netfilter_pre_routing: 2 callbacks suppressed
2021-01-25T15:39:56+01:00 kernel: [588328.173087] fp_netfilter_pre_routing: 2 callbacks suppressed
2021-01-25T15:39:37+01:00 kernel: [588309.847290] fp_netfilter_pre_routing: 2 callbacks suppressed
2021-01-25T15:38:56+01:00 kernel: [588268.037006] fp_netfilter_pre_routing: 2 callbacks suppressed
2021-01-25T15:38:26+01:00 kernel: [588237.925263] fp_netfilter_pre_routing: 2 callbacks suppressed
2021-01-25T15:36:55+01:00 kernel: [588147.576911] fp_netfilter_pre_routing: 2 callbacks suppressed
2021-01-25T15:35:55+01:00 kernel: [588087.344156] fp_netfilter_pre_routing: 2 callbacks suppressed
2021-01-25T15:35:25+01:00 kernel: [588057.252905] fp_netfilter_pre_routing: 2 callbacks suppressed
2021-01-25T15:34:55+01:00 kernel: [588027.177592] fp_netfilter_pre_routing: 2 callbacks suppressed
2021-01-25T15:34:35+01:00 kernel: [588007.219566] fp_netfilter_pre_routing: 2 callbacks suppressed
2021-01-25T15:34:25+01:00 kernel: [587997.082485] fp_netfilter_pre_routing: 4 callbacks suppressed
2021-01-25T15:29:54+01:00 kernel: [587726.118453] fp_netfilter_pre_routing: 2 callbacks suppressed
2021-01-25T15:28:54+01:00 kernel: [587665.912502] fp_netfilter_pre_routing: 2 callbacks suppressed
2021-01-25T15:26:23+01:00 kernel: [587515.472872] fp_netfilter_pre_routing: 2 callbacks suppressed
2021-01-25T15:25:38+01:00 kernel: [587470.732651] fp_netfilter_pre_routing: 8 callbacks suppressed
2021-01-25T15:25:23+01:00 kernel: [587455.286447] fp_netfilter_pre_routing: 2 callbacks suppressed
2021-01-25T15:24:53+01:00 kernel: [587425.206582] fp_netfilter_pre_routing: 2 callbacks suppressed
2021-01-25T15:23:53+01:00 kernel: [587365.025773] fp_netfilter_pre_routing: 2 callbacks suppressed
2021-01-25T15:22:53+01:00 kernel: [587304.922332] fp_netfilter_pre_routing: 2 callbacks suppressed
2021-01-25T15:19:29+01:00 kernel: [587101.162756] fp_netfilter_pre_routing: 4 callbacks suppressed
2021-01-25T15:18:22+01:00 kernel: [587034.047771] fp_netfilter_pre_routing: 2 callbacks suppressed
2021-01-25T15:14:51+01:00 kernel: [586823.413794] fp_netfilter_pre_routing: 10 callbacks suppressed
what kind of traffic(bandwidth) you see or monitored ?
BB
NivNiv
Is there any solution? I have the same problem, tried to upgrade to 1.0.03.21 but still the log full with 2021-04-17T15:08:07+02:00 <warning>kernel: [ 569.214555] fp_netfilter_pre_routing: 15 callbacks suppressed
Good evening,
Not realy. Contacted Cisco through Tech Data and the only they could come back with was 'to disable webfiltering alert messages'.
Cheers,
Michael
Hi Michael,
Thank you for the answer, I did try to disable the web filter category in the log settings but still the events are written, I assume the reason is the events written by "Kernel" and not web filter, unfortunately I don't have tech support, do you have any suggestions?
Niv
removed. see my next post.
esav
Related to upnp. Disabling it, and those warnings disappeared. Enabling it, they came back.
2021-06-16T07:33:30+03:00 <notice>miniupnpd: HTTP listening on port 36240
2021-06-16T07:33:30+03:00 <notice>miniupnpd: HTTP IPv6 address given to control points : [fec0:1::1]
2021-06-16T07:33:30+03:00 <notice>miniupnpd: Listening for NAT-PMP/PCP traffic on port 5351
2021-06-16T07:33:43+03:00 <warning>kernel: [240064.169619] fp_netfilter_pre_routing: 15 callbacks suppressed
2021-06-16T07:34:49+03:00 <warning>kernel: [240130.178781] fp_netfilter_pre_routing: 15 callbacks suppressed
2021-06-16T07:35:55+03:00 <warning>kernel: [240196.188080] fp_netfilter_pre_routing: 19 callbacks suppressed
2021-06-16T07:37:01+03:00 <warning>kernel: [240262.197159] fp_netfilter_pre_routing: 15 callbacks suppressed
2021-06-16T07:38:07+03:00 <warning>kernel: [240328.206624] fp_netfilter_pre_routing: 9 callbacks suppressed
2021-06-16T07:39:13+03:00 <warning>kernel: [240394.215889] fp_netfilter_pre_routing: 9 callbacks suppressed
2021-06-16T07:40:02+03:00 <warning>kernel: [240443.065090] fp_netfilter_pre_routing: 1 callbacks suppressed
2021-06-16T07:40:17+03:00 <warning>kernel: [240458.485650] fp_netfilter_pre_routing: 2 callbacks suppressed
2021-06-16T07:40:38+03:00 <warning>kernel: [240479.167456] fp_netfilter_pre_routing: 7 callbacks suppressed
2021-06-16T07:41:26+03:00 <warning>kernel: [240527.174381] fp_netfilter_pre_routing: 9 callbacks suppressed
2021-06-16T07:43:36+03:00 <warning>kernel: [240656.849549] fp_netfilter_pre_routing: 8 callbacks suppressed
2021-06-16T07:44:14+03:00 <warning>kernel: [240694.871419] fp_netfilter_pre_routing: 7 callbacks suppressed
2021-06-16T07:45:48+03:00 <warning>kernel: [240789.152024] fp_netfilter_pre_routing: 7 callbacks suppressed
2021-06-16T07:46:37+03:00 <warning>kernel: [240837.692552] fp_netfilter_pre_routing: 7 callbacks suppressed
2021-06-16T07:48:00+03:00 <warning>kernel: [240921.394284] fp_netfilter_pre_routing: 2 callbacks suppressed
2021-06-16T07:49:06+03:00 <warning>kernel: [240987.515599] fp_netfilter_pre_routing: 1 callbacks suppressed
2021-06-16T07:49:36+03:00 <warning>kernel: [241017.106396] fp_netfilter_pre_routing: 2 callbacks suppressed
2021-06-16T07:51:19+03:00 <warning>kernel: [241119.848030] fp_netfilter_pre_routing: 1 callbacks suppressed
2021-06-16T07:51:32+03:00 <warning>kernel: [241133.495609] fp_netfilter_pre_routing: 1 callbacks suppressed
2021-06-16T07:53:31+03:00 <warning>kernel: [241252.240369] fp_netfilter_pre_routing: 2 callbacks suppressed
2021-06-16T07:54:02+03:00 <warning>kernel: [241282.797148] fp_netfilter_pre_routing: 1 callbacks suppressed
2021-06-16T07:55:44+03:00 <warning>kernel: [241384.592733] fp_netfilter_pre_routing: 2 callbacks suppressed
2021-06-16T07:56:29+03:00 <warning>kernel: [241430.437054] fp_netfilter_pre_routing: 1 callbacks suppressed
2021-06-16T07:57:56+03:00 <warning>kernel: [241516.845229] fp_netfilter_pre_routing: 2 callbacks suppressed
2021-06-16T07:59:01+03:00 <warning>kernel: [241582.257793] fp_netfilter_pre_routing: 1 callbacks suppressed
2021-06-16T07:59:54+03:00 <warning>kernel: [241635.060958] fp_netfilter_pre_routing: 2 callbacks suppressed
2021-06-16T08:01:14+03:00 <warning>kernel: [241715.268803] fp_netfilter_pre_routing: 9 callbacks suppressed
2021-06-16T08:02:20+03:00 <warning>kernel: [241781.415804] fp_netfilter_pre_routing: 2 callbacks suppressed
2021-06-16T08:03:21+03:00 <warning>kernel: [241842.443943] fp_netfilter_pre_routing: 1 callbacks suppressed
2021-06-16T08:04:33+03:00 <warning>kernel: [241913.903929] fp_netfilter_pre_routing: 2 callbacks suppressed
2021-06-16T08:05:26+03:00 <warning>kernel: [241966.916292] fp_netfilter_pre_routing: 1 callbacks suppressed
2021-06-16T08:06:45+03:00 <warning>kernel: [242046.464871] fp_netfilter_pre_routing: 2 callbacks suppressed
2021-06-16T08:07:29+03:00 <warning>kernel: [242090.092841] fp_netfilter_pre_routing: 1 callbacks suppressed
2021-06-16T08:08:09+03:00 <warning>kernel: [242130.336083] fp_netfilter_pre_routing: 2 callbacks suppressed
2021-06-16T08:09:33+03:00 <warning>kernel: [242214.108634] fp_netfilter_pre_routing: 1 callbacks suppressed
2021-06-16T08:11:10+03:00 <warning>kernel: [242310.949656] fp_netfilter_pre_routing: 2 callbacks suppressed
2021-06-16T08:11:35+03:00 <warning>kernel: [242336.437285] fp_netfilter_pre_routing: 1 callbacks suppressed
2021-06-16T08:13:22+03:00 <warning>kernel: [242443.192052] fp_netfilter_pre_routing: 2 callbacks suppressed
2021-06-16T08:13:41+03:00 <warning>kernel: [242462.224577] fp_netfilter_pre_routing: 1 callbacks suppressed
2021-06-16T08:15:34+03:00 <warning>kernel: [242575.434371] fp_netfilter_pre_routing: 2 callbacks suppressed
2021-06-16T08:15:42+03:00 <warning>kernel: [242583.250522] fp_netfilter_pre_routing: 1 callbacks suppressed
2021-06-16T08:17:47+03:00 <warning>kernel: [242707.676912] fp_netfilter_pre_routing: 2 callbacks suppressed
2021-06-16T08:18:22+03:00 <warning>kernel: [242742.967190] fp_netfilter_pre_routing: 2 callbacks suppressed
2021-06-16T08:19:51+03:00 <warning>kernel: [242831.783207] fp_netfilter_pre_routing: 1 callbacks suppressed
2021-06-16T08:21:05+03:00 <warning>kernel: [242906.040329] fp_netfilter_pre_routing: 2 callbacks suppressed
2021-06-16T08:21:43+03:00 <warning>kernel: [242943.941679] fp_netfilter_pre_routing: 1 callbacks suppressed
2021-06-16T08:23:17+03:00 <warning>kernel: [243038.282834] fp_netfilter_pre_routing: 2 callbacks suppressed
2021-06-16T08:23:44+03:00 <warning>kernel: [243065.305038] fp_netfilter_pre_routing: 1 callbacks suppressed
2021-06-16T08:25:29+03:00 <warning>kernel: [243170.525186] fp_netfilter_pre_routing: 2 callbacks suppressed
2021-06-16T08:25:55+03:00 <warning>kernel: [243195.871506] fp_netfilter_pre_routing: 1 callbacks suppressed
2021-06-16T08:27:42+03:00 <warning>kernel: [243302.767665] fp_netfilter_pre_routing: 2 callbacks suppressed
2021-06-16T08:27:47+03:00 <warning>kernel: [243308.402039] fp_netfilter_pre_routing: 1 callbacks suppressed
2021-06-16T08:29:54+03:00 <warning>kernel: [243435.010031] fp_netfilter_pre_routing: 7 callbacks suppressed
2021-06-16T08:30:32+03:00 <warning>kernel: [243473.125761] fp_netfilter_pre_routing: 7 callbacks suppressed
2021-06-16T08:32:04+03:00 <warning>kernel: [243565.083152] fp_netfilter_pre_routing: 7 callbacks suppressed
2021-06-16T08:32:11+03:00 <warning>kernel: [243571.951841] fp_netfilter_pre_routing: 18 callbacks suppressed
2021-06-16T08:33:09+03:00 <warning>kernel: [243629.677163] fp_netfilter_pre_routing: 2 callbacks suppressed
2021-06-16T08:34:18+03:00 <warning>kernel: [243699.504757] fp_netfilter_pre_routing: 9 callbacks suppressed
2021-06-16T08:35:25+03:00 <warning>kernel: [243765.625966] fp_netfilter_pre_routing: 7 callbacks suppressed
2021-06-16T08:35:40+03:00 <warning>kernel: [243780.595286] fp_netfilter_pre_routing: 7 callbacks suppressed
2021-06-16T08:37:37+03:00 <warning>kernel: [243897.868451] fp_netfilter_pre_routing: 7 callbacks suppressed
2021-06-16T08:38:11+03:00 <warning>kernel: [243932.202267] fp_netfilter_pre_routing: 7 callbacks suppressed
2021-06-16T08:39:49+03:00 <warning>kernel: [244030.110701] fp_netfilter_pre_routing: 7 callbacks suppressed
2021-06-16T08:40:11+03:00 <warning>kernel: [244052.178445] fp_netfilter_pre_routing: 7 callbacks suppressed
2021-06-16T08:41:22+03:00 <warning>kernel: [244123.512790] fp_netfilter_pre_routing: 7 callbacks suppressed
2021-06-16T08:42:50+03:00 <notice>miniupnpd: shutting down MiniUPnPd
2021-06-16T12:57:09+03:00 <alert>Webfilter: INFO : Freeing old LocalDB memory !!!!
2021-06-16T12:57:09+03:00 <alert>Webfilter: INFO : Updated LocalDB memory !!!!
2021-06-16T12:57:29+03:00 <warning>PnP: [10350]: pnp.infra.Profile.1 WARNING Config file does not contain 'modified' optionin section 'Profile 1'
2021-06-16T13:12:01+03:00 <error>Webfilter: BCAP server error (705): Invalid RTU version
upnp was the first one, next plugged in Jensen Airlink in wifi ap mode (no router / 4g wan features active even though it has them, just needed one additional wifi ap for testing purposes) , next thing I know this happens
2021-06-19T09:09:03+03:00 <warning>kernel: [504984.048855] fp_netfilter_pre_routing: 148 callbacks suppressed
2021-06-19T09:09:09+03:00 <warning>kernel: [504990.048836] fp_netfilter_pre_routing: 29 callbacks suppressed
2021-06-19T09:09:15+03:00 <warning>kernel: [504996.135994] fp_netfilter_pre_routing: 28 callbacks suppressed
2021-06-19T09:09:21+03:00 <warning>kernel: [505002.173167] fp_netfilter_pre_routing: 11 callbacks suppressed
2021-06-19T09:09:26+03:00 <warning>kernel: [505007.921204] fp_netfilter_pre_routing: 18 callbacks suppressed
2021-06-19T09:09:32+03:00 <warning>kernel: [505013.525819] fp_netfilter_pre_routing: 1691 callbacks suppressed
2021-06-19T09:09:37+03:00 <warning>kernel: [505018.549040] fp_netfilter_pre_routing: 311 callbacks suppressed
2021-06-19T09:09:42+03:00 <warning>kernel: [505023.622089] fp_netfilter_pre_routing: 212 callbacks suppressed
2021-06-19T09:09:48+03:00 <warning>kernel: [505029.329635] fp_netfilter_pre_routing: 100 callbacks suppressed
2021-06-19T09:09:54+03:00 <warning>kernel: [505035.305439] fp_netfilter_pre_routing: 40 callbacks suppressed
2021-06-19T09:09:59+03:00 <warning>kernel: [505040.770524] fp_netfilter_pre_routing: 6 callbacks suppressed
2021-06-19T09:10:04+03:00 <warning>kernel: [505045.846677] fp_netfilter_pre_routing: 592 callbacks suppressed
2021-06-19T09:10:10+03:00 <warning>kernel: [505051.113808] fp_netfilter_pre_routing: 197 callbacks suppressed
2021-06-19T09:10:15+03:00 <warning>kernel: [505056.506134] fp_netfilter_pre_routing: 173 callbacks suppressed
2021-06-19T09:10:20+03:00 <warning>kernel: [505061.567642] fp_netfilter_pre_routing: 56 callbacks suppressed
the second I unplug Jensen, these stop... that ap didn't even have any clients connected yet. This is weird.
