09-20-2011 04:10 AM
i have an rvl200 Router and the ssl-vpn-tunnel is working fine under windows and linux.
Now i bought a Nexus S with Android 2.3.3 and would like to create an vpn-connection to my router too.
But the Applet, like on linux is not starting.
Has anyone a solution to this problem?
Kind Regards,
Tobi
09-21-2011 01:40 AM
you might want to try the built in PPTP VPN client on android, since i doubt SSL VPN will work with a Android phone as yet.
http://www.techrepublic.com/blog/smartphones/connect-to-a-pptp-vpn-from-your-android-phone/2145
02-06-2012 09:08 AM
Hi Simon,
thank you for your replay.
I tried it, but without any success.
Kind Regards,
Tobi
