RVL200 Virtual Passage on Android
LorentzTobias
i have an rvl200 Router and the ssl-vpn-tunnel is working fine under windows and linux.
Now i bought a Nexus S with Android 2.3.3 and would like to create an vpn-connection to my router too.
But the Applet, like on linux is not starting.
Has anyone a solution to this problem?
Kind Regards,
Tobi
linksysinfo
Level 4
Level 4
you might want to try the built in PPTP VPN client on android, since i doubt SSL VPN will work with a Android phone as yet.
http://www.techrepublic.com/blog/smartphones/connect-to-a-pptp-vpn-from-your-android-phone/2145
Regards Simon
Hi Simon,
thank you for your replay.
I tried it, but without any success.
Kind Regards,
Tobi
