RVS 4000 QoS Implementation
derekalex
Hi Folks,
Does anyone know where to find a good explanation of the QoS configuration approach for this device ?
The Device Help Files are very limited in their explanation and the Admin guide is not much better.
I've searched through Web Sites, but none of them describe how the Router treats packets across the interfaces.
How does it queue with CoS VS Trusted Ports ??
How does it treat packets from each LAN port destined for the WAN side ?
How does it treat packets in the reverse direction ?
Derek
