06-17-2010 02:55 PM
People,
Looks like I have another cryptic message from my RVS-4000 V1.3.2.0:
Jun 13 16:54:50 - Dead loop on virtual device sit1, fix it urgently!
Jun 13 16:54:53 - Dead loop on virtual device sit1, fix it urgently!
Jun 13 16:54:59 - Dead loop on virtual device sit1, fix it urgently!
Remember, my RVS-4000 is setup for 0-3 Log Levels:
Log Level
Setting which level log Router should recorder. Level from 0 ~ 7 means:
0: LOG_EMERG(system is unusable)
1: LOG_ALERT(action must be taken immediately)
2: LOG_CRIT(critical conditions)
3: LOG_ERR(error conditions)
4: LOG_WARNING(warning conditions)
5: LOG_NOTICE(normal, but significant, condition)
6: LOG_INFO(informational message)
7: LOG_DEBUG(debug-level message)
So, when I get any messages... I'm a little concerned. Because the RVS-4000 V1.3.2.0 thinks it's an Error or better.
Thanks ahead of time!
Bruce :-|
07-18-2010 04:54 PM
I was receiving this message too. Until I set IP Mode to IPv4 Only. Error messages stopped.
This may not be very helpful if you need IPv6. But I suspect you don't because I think this error message implies that something is very wrong with IPv6 configuration. If you needed it, you'd have noticed that it wasn't working. Look here: http://linux.die.net/man/8/isatapd
Surely there are other ways to say whatever it is this message is saying so I think it is probably safe to assume it is the exact same code that generated the error for the same reason.
11-06-2010 06:06 AM
Thank you for this information...
I will try turning IPV6 off.
Bruce
