RVS4000 Stops routing daily
kcconsulting
I have an RVS4000 that needs to be power cycled daily because it stops routing. i have checked the logs and no intrusions have occured and there is nothing stating that the routing has stopped. IPS is enabled as well as VPN. Firmware has been updated to the latest. Please assist.
riroe
Level 3
Level 3
To get a better understanding of your problem with the router I would suggest that you place a call to our Cisco Small Business Support Center
at 1-866-606-1866 so that a case can be opened for you on this problem.
THANKS
