RVS4000 to RV325 - Port Forwarding help needed!
dtos01
The RVS4000 has "Single Port Forwarding" but I can't find that setting in the RV325... Pls advise!
Thx.
drmciscoccna
D,
that is accomplished through the Port address translation under setup.
you need to go into the service management button and edit an existing entry or create your own. this page allows you to enter the external and internal ports then name it as you see fit.
you then click the add button and select the service you created, enter the destination IP and enable it.
Fairly simple, you just have to know where to look!
good luck
THANK YOU!!!!!
For Port Range Forwarding there is only an option for TCP or UDP not both (like the RVS4000)... Does this mean I have to duplicate entries? i.e., one for TCP and one for UDP?
Thx!
David
I suppose you could just give it a different name like myservice and myservice1.
they are different protocols so that should work but why would you need both?.
