Setup PPTP and forced to reset router IP to 10.x.x.1 to avoid conflict
thomashfchow
Hi! I bought a RV110W yesterday to create a simple wireless connection with VPN capability. I followed the starting guide and completed the physical connection of the modem. Now I have LAN and wireless internet connection. I come to the VPN tab, enabled it and added a new row with my choice of user name and password.
I have the default setting unchanged such as
IP for PPTP server 10.0.0.1
IP for PPTP clients 10.0.0.10 to 14
MPPE encryption Enabled
Netbios over VPN no tick
Then I got this caution popped up as per attached. I didn't really understand what it meant and I pressed OK to continue. After a while the router seemed to have resetted itself, but I no longer able to find the GUI from 192.168.1.1 anymore.
What had happened? and how can I set up the PPTP connection on the router? How can I find the GUI again? Many thanks!
Thomas Chow
Tom Watts
Hi Thomas, if using a windows computer, you can perform an ipconfig on a command prompt, the default gateway is the router IP.
-Tom
Please rate helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
