SRP 527W issue
ASRIARISNANI
Hi, I have basic cisco small business pro SRP500 series router (SRP 527W). The router then connected to a firewall and another core switch and then to host (PC and laptops). My question is, when I enter the router webpage to do configuration, why other PC also can access the router webpage without need to enter username and password? Is there any issue or its just because layer 2 device (core switch)?
If I correctly understood, your router is connected to a firewall then to L2 switch:
SRP500 --- firewall --- L2 switch with PC
Do you know if your firewall acts as a WEB proxy? This can be the cause of a directly access.
Regards.
