SRP 546w adsl+ Annex B adsl configuration problem.
jonathanb355
Dear All,
           I have the above router trying to use to access BT ADSL 2+ circuit. It came with BT home hub which works fine. I need to use this circuit for our Guest WiFi therefore needed to swap the BT Homehub for cisco SRP 546w ADSL+ Annex B.  After being through all the configurations when I connect the line to the DSL port the light aren't able to come up.  When I chceked on the status it showing as DSL Modulation  Not Trained .
Any ideas?
Andrew Hickman
Hi Jonathan,
Unfortunately, you have the wrong product for connection to a BT service.  The SRP546 is used for connection to ADSL services delivered over digital ISDN telephone lines.
For the UK, you will need the SRP547, which works with ADSL services delivered over analogue telephone lines.
Andy
Andrew Hickman
Hi Jonathan,
Andy
Thanks Andrew, there was a mix up in the order.
