SRP527W incoming voice calls
dc
I have just set up a new SRP527W ADSL VOIP Wireless modem.
I have configured the VOIP set up to my provider and every thing is working fine for outgoing calls.
However using the same set up for incoming call the digital hadset is not registering the incoming call (ie not ringing)
I have an ADSL port filter on the incoming line, unfiltered port is plugged into the DSL port on router.
Which port should I plug the digital handset into (FXO?)
Are there any more setting I need to modify to accept incoming calls through the modem?
Any asistance would be greatly appreciated..
paolo bevilacqua
Wrong forum, try "small business - routers". You can move the post using the control panel on the right.
