Subnet Mask fixed limitation of Cisco RV325
shrmitadmin
I am having big frustration with the subnet Mask limitation with the RV325 .
I would like need to do 255.255.254.0  . Is there someone who can help please ?
6 Replies 6
I guess you need to use a class-b private network.172.16.0.0/12
But intresting to see this type to limitation.
Thank u for your reply vivek srivastava!
I already tried and it does not even allow to save .
"Device IP last value is out of range "
refer to the screenshot attached.
Hope someone will be able to guide me .
try with device ip - 172.16.0.1
172.16.0.1
already tried with that too .
can't .
Michael Vandergrift
The RV325, like all Cisco small business routers is limited to a /24 subnet.  If you need more IP addresses you can create another VLAN.
Mike.V
Posts in this discussion have been modified due to possible misconduct. Please refer to the CSC terms of use for more details. https://supportforums.cisco.com/document/29951/cisco-support-community-acceptable-use-agreement
