05-25-2015 10:55 PM
I am having big frustration with the subnet Mask limitation with the RV325 .
I would like need to do 255.255.254.0 . Is there someone who can help please ?
05-25-2015 11:43 PM
I guess you need to use a class-b private network.172.16.0.0/12
But intresting to see this type to limitation.
05-26-2015 12:17 AM
05-26-2015 12:51 AM
try with device ip - 172.16.0.1
05-26-2015 12:56 AM
172.16.0.1
already tried with that too .
can't .
05-26-2015 11:29 AM
The RV325, like all Cisco small business routers is limited to a /24 subnet. If you need more IP addresses you can create another VLAN.
Mike.V
06-24-2015 11:00 AM
Posts in this discussion have been modified due to possible misconduct. Please refer to the CSC terms of use for more details. https://supportforums.cisco.com/document/29951/cisco-support-community-acceptable-use-agreement |
Thank u for your reply vivek srivastava!
I already tried and it does not even allow to save .
"Device IP last value is out of range "
refer to the screenshot attached.
Hope someone will be able to guide me .
