Swapping 887VA-K9 for 897VA-K9 results in weird network behaviour and no Wan traffic
antonical
Hi we are trying to swap out an old 887VA-K9 with a new 897VA-K9 and having some issues.
We have used the same or essentially the same config on both. The 887 works and our OPNSense FW/Router can login via a PPPoE connection and is assigned our Public IP's correctly etc.
When we put the 897 in place it also connects and our OPNSense can login via a PPPoE connection and is assigned our PUblic IP's correctly. However we get weird behaviour on the network and cannot seem to get traffic into and out of the WAN interface.
Can someone take a look at the config below and see if there is anything obvious we are missing.
887 Config:
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service internal
service sequence-numbers
hostname
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 51200
logging console critical
enable secret
enable password
aaa new-model
aaa authentication login local_authen local
aaa authorization exec local_author local
aaa session-id common
memory-size iomem 25
clock timezone GMT 0 0
no ip source-route
no ip routing
no ip domain lookup
no ip cef
no ipv6 cef
license udi pid CISCO887VA-M-K9
license accept end user agreement
license boot module
username
controller VDSL 0
operating mode vdsl2
modem ukfeature
bridge irb
interface Ethernet0
no ip address
no ip route-cache
interface Ethernet0.101
encapsulation dot1Q 101
no ip route-cache
bridge-group 1
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
interface FastEthernet0
no ip address
duplex full
speed 100
interface FastEthernet1
no ip address
duplex full
speed 100
interface FastEthernet2
no ip address
duplex full
speed 100
interface FastEthernet3
no ip address
duplex full
speed 100
interface Vlan1
no ip address
ip virtual-reassembly in
no ip route-cache
bridge-group 1
no ip forward-protocol nd
no ip http server
no ip http secure-server
logging trap debugging
bridge 1 protocol ieee
end
897 Config:
no service pad
service internal
hostname
enable secret
enable password
aaa new-model
no ip source-route
no ip routing
no ip domain lookup
no ip cef
no ipv6 cef
username
controller VDSL 0
modem ukfeature
bridge irb
interface Ethernet0
no ip address
no ip route-cache
no ip route-cache
bridge-group 1
interface ATM0
no ip address
shutdown
interface GigabitEthernet0
no ip address
duplex full
speed auto
interface GigabitEthernet1
no ip address
duplex full
speed auto
interface GigabitEthernet2
no ip address
duplex full
speed auto
interface GigabitEthernet3
no ip address
duplex full
speed auto
interface GigabitEthernet4
no ip address
duplex full
speed auto
interface GigabitEthernet5
no ip address
duplex full
speed auto
interface GigabitEthernet6
no ip address
duplex full
speed auto
interface GigabitEthernet7
no ip address
duplex full
speed auto
interface GigabitEthernet8
no ip address
duplex full
speed auto
interface Vlan1
no ip address
no ip route-cache
bridge-group 1
no ip http server
end
Cheers
Tony
0 Replies 0
