How does one correctly tighten a screw on a device?
I recently ran into a situation where a serial cable was too tight, and I called someone for help.
Does anyone think that a torque wrench is useful to have, or would it be an unnecessary convenience.
Does anyone recommend a specific torque wrench, why. What do I have to know to use it correctly. Can you give me a tutorial.
What are the benefits of a cheap torque wrench versus an expensive one.
Thank you,
phil.z456
