wan 1 e wan 2
flaviopanissa1
Olá, tenho um cisco RV320 e estou utilizando 2 wan, e estou utilizando o smart link backup (wan1) primary. nao estou conseguindo fazer a wan2 subir quando cai a internet, mas quando faço isso manualmente desconectando o cabo atras ai sim funciona. Onde estou errando?
Aztec_
Hi flav,
When the internet fails, can you ping wan1 peer IP?? What routing are you using??
Actually i never configured RV before, but according to my experience with usual cisco router, if we use default static route to internet side, backup internet link will not be used as long as the primary link is still up.
Means if the internet fails on ISP side, router is not aware, they only maintain their neighbor device link status. Unless tracking is configured.
This discussion has been reposted from Additional Communities to the Small Business Routers community.
